Secondary Air Injection
Old Sep 21, 2019 | 07:25 PM
bwessale's Avatar
Question Secondary Air Injection
I'm installing a 4.6L Thor engine from an '01 Range Rover into a British sports car. I've discovered the engine has Secondary Air Injection. I have learned that the SAI system is needed to keep the ECU happy, but I am tossing out the stock ECU/BCM and converting to Megasquirt. I live in rural TX where there are no emissions tests, and I plan to register the car as a '68, since that's what the car VIN identifies.
So, can I remove the SAI stuff - the valves on each cylinder bank, their hoses and the pump? If so, do I need to do anything more that plug the SAI injector sockets in the heads?.
And why are there two radiators available - one for the non-SAI 4.6L and one or the SAI-equipped 4,6L? Do SAI equipped engines run hotter and therefore the heads need more cooling?
Thanks,
Bill
Old Sep 22, 2019 | 09:30 AM
Nosugar0carbs's Avatar
Thanks,
Bill
As far as the ports on the heads, you can plug them(tap and bolt), if you are going to megasquirt ecu, you don’t need the harness connections. The radiator difference is just a port for a temp sensor to activate the vacuum pump for the SAI, doesn’t have to be directly attached to have a “reading” if you are going to utilize SAI. If you aren’t using the emissions, no need for it.
Old Sep 22, 2019 | 02:20 PM
bwessale's Avatar
Thanks Nosugar0Carbs. That's the information I needed.
Old Sep 22, 2019 | 06:28 PM
No worries, fairly easy question. Ask all you want/like.
zuke
Apr 23, 2018 09:33 PM
Jeff Blake
Aug 29, 2016 11:28 AM
mule2ears
Nov 5, 2015 11:37 AM
RegT
Mar 18, 2013 05:20 AM
aublec22
Mar 20, 2011 01:28 PM
