SLS with lift
Old Feb 28, 2018 | 07:58 AM
Pcamz's Avatar
Default SLS with lift
Hi All,
Has anyone done a 2" lift on a Disco 2 with SLS using an approximate standard length shock?
I recently did a fair amount of work getting mine back on the road and got 4 nitro max RAW 4x4 shocks which they say are suitable for 0-50mm lift. (Keeping the same travel as stock)
It is important to note they are not extended length shocks. I am thinking if I fit a lift spacer and hit the extended mode the shocks will top out?
Some rough measurements seemed to indicate this might be the case. I read some people have done this with OME shocks which are pretty close to stock length
Will the system keep trying to reach the limit it it tops out?
I don't think you can adjust the extended modes offset from ride height either, just the normal ride height. I have a programmer to set that.
(Dialing back the extended height would be a nice trick without modifying the base ride height)
Thanks for reading
twr7cx
Sep 27, 2011 07:52 AM
humroot
Jun 7, 2011 04:34 PM
B@tt
Jan 10, 2009 05:18 PM
humroot
Mar 19, 2008 12:49 PM
