suspension help
Old Jun 5, 2007 | 08:31 PM
eriqcharlz's Avatar
Default suspension help
First of all I would like to extend many, many, many thanks to DiscoMike for all the assistance and advice, my '00 Disco II is running superb! I just got my head gaskets replaced........OUCH!!!! Next month I would like to do a few things to the suspension and brakes. I have read on here that slotted and drilled rotors are a good choice with kevlar brakes, so I think my mind is made up with that. I will also be replacing the factory brake lines with stainless steel ones. Moving on to the suspension; I will probably be putting in Bilstein shocks as well as a Bilstein steering damper. I don't do much off roading as there arent any places, that I know of, to do so in San Antonio. Should I also have the coils replaced? What about the bushings? Any suggestions or feed back would be great. I did notice a "package" on Atlantic British that included the shocks (Old Man Emu), coils and bushings (I think they are the bushings), sorry, still trying to learn the terminology. Thanks again. [sm=smiley20.gif]
Old Jun 6, 2007 | 07:29 AM
Default RE: suspension help
Year and mpdel. how many miles on the truck?
Mike
Old Jun 6, 2007 | 03:55 PM
eriqcharlz's Avatar
its a 2000 Disco II with approximately 95k miles
Old Jun 6, 2007 | 05:31 PM
Well with that mileage you are ready for a lift, I would replace the bubber brake lines and do a full flush, Inspect and most likely rebuild the front drive shaft and other stuff depending on the wallet and the need.
You might want to call me sometime and we can go all thru it.
Mike
303-862-7680
Old Jun 6, 2007 | 06:07 PM
eriqcharlz's Avatar
As per one of our previous conversations I have already had the drive shaft rebuilt. I will also be having the brake system flushed when I get the brakes, shocks, etc. in my posession. What are your thoughts on my original inquiry?
Old Jun 6, 2007 | 07:18 PM
Sorry, I don't remember what inquirey you are speaking about, old age thing.
By the way, when you get ready for the brakes, go check out the DBA package Steve has, http://www.dap-inc.com/homeframe.htm
Mike
TRIARII
Jun 30, 2022 09:48 AM
ljdiscovery
Feb 13, 2016 11:21 PM
Aaron Sandland
Feb 12, 2015 09:35 AM
fastrx7man
Jan 28, 2012 12:49 PM
Speed racer
Oct 11, 2008 10:56 PM
