terrafirma steering
Old Aug 6, 2014 | 09:59 AM
fishEH's Avatar
Originally Posted by TOM R
Sorry been away, cupgt said call
Ask for inserts for 1"I.d. tubing threaded 11/16" x 18 , 2 left and 2 right with jamb nuts
Will try to call today
Cool. Let me know what they say and if there's any kind of minimum order/quantity discount. Thanks!
Old Aug 6, 2014 | 01:24 PM
TOM R's Avatar
Spoke with summit machine, she will do 15 each on the adapters, 10 each on the nuts I placed an order she will be doing them next week or 2 with a similar run, if you want in call and tell her for rover and same as Ian and tom
now she did suggest doing all aluminum
They produce true for jeeps and trucks in an a
Aluminum. With memory that if you bend on rocks if bends right back, these should be threaded out size, tapered ends and machined wrench flats, quoted 298 for the pair plus shipping, I may change my order to that got to think on it
Old Aug 6, 2014 | 01:55 PM
fishEH's Avatar
Aluminum? As in aluminum tube and adapters instead of DOM?
Hmmm, IDK. DOM is pretty stout stuff. I highly doubt it would get bent. Two 48" lengths of DOM is about $106 shipped from Ruffstuffspecialties.com Add another $100 for the ends and nuts.
Old Aug 6, 2014 | 02:15 PM
TOM R's Avatar
Think she was talking solid aluminum rod drilled and tapped
Old Aug 6, 2014 | 02:20 PM
fishEH's Avatar
Ahhh, ok. IDK seems like it'd be nice but probably overkill for a Disco.
Ian said you need about 3' and 4' lengths of 1.5" DOM which is $92 shipped. I'll probably do that with the adapters and nuts from Summit and sell my RTE stuff.
Old Aug 6, 2014 | 04:18 PM
TOM R's Avatar
I just don't want to be 200 into tubing and bend one then have to spend the $ again, I don't go looking to wheel hard so idk which way to go
Old Aug 6, 2014 | 05:14 PM
fishEH's Avatar
I had RoverTracks steering. It was stout, I should have kept it. I have RTE SS steering now. It's ok but it's stainless and softer than DOM. The drag link has just the faintest bend in it.
I run front and rear air lockers on 35's and will be going 1.5", 1/4" wall DOM. All the other kit HD steering including RTE and RoverTracks is 1.25" and 1/8" wall.
Old Aug 6, 2014 | 05:34 PM
TOM R's Avatar
Yeah. I will probly do the Dom , spend the $ elsewhere
Old Aug 8, 2014 | 12:36 PM
CUpgt's Avatar
Check with Barnes 4x4 on Dom. He has killer shipping prices and is great to work with
Old Aug 8, 2014 | 06:11 PM
TOM R's Avatar
Should be able to get it local
Ian you sure on the 11/16 x 18 pitch?
