tires for a 2 inch lift
Old Feb 2, 2015 | 10:26 PM
Tomhenge's Avatar
Default tires for a 2 inch lift
does anybody have a suggestion on what size tires I should get for a 2003 disco with 2 in lift? I'm looking for an AT. 18 inch rims
Old Feb 3, 2015 | 09:48 AM
mattmo78's Avatar
I have a '99 with a 2" lift. Right now, I'm running the Nitto Terra Grapplers in stock tire size because I had to get tires before I got the lift. When my tires are ready to change, I'm most likely going to go with Terra Grapplers in 275/65-18. They are 32" diameter, about 10.8" wide, with a 7" sidewall (roughly).
I like the Terra Grapplers as they handle well on the road and are quite, but they still do well off pavement too. Our D2 is mostly a road warrior (daily driver). And, I've had good luck with them in the snow in the past 2 years... haven't been lucky enough to drive in snow this year.
Old Mar 9, 2015 | 07:59 PM
Freedom38's Avatar
I also run the 18" rims. I have a 2 inch spacer lift on mine. So probably about 1.5 inches counting the sag in the old springs. I was able to fit 33" BF Goodrich All Terrains on mine. I did have to trim the front bumper just a hair, But it was worth it.
Old Mar 10, 2015 | 12:40 AM
frankie_500's Avatar
I had my front lifted 2 in, with TSB rear lifts. I'm running on procomp xtreme M/T 265/75/16. Size might work with yr 18 in rims too.
LiamH
Jan 20, 2015 02:19 PM
svntsvn
Jan 16, 2015 07:59 AM
wilson96rr
Jun 13, 2012 05:14 PM
Joebern
Jun 21, 2011 05:09 PM
morfa
Aug 27, 2006 01:22 PM
