Trying to figure out the exhaust.
When people say they're going to put a straight pipe on are they taking the muffler off, replacing it with just pipe and leaving the resonator? I wanna get some decent growl w/o the wife murdering me cuz the rover sounds like a monster truck! Lol. I've read the other threads but I'm just double checking. Thanks in advance.
Turn Down Tip
Go on You Tube and Type in Land Rover Discovery Exhaust, You'll come up with endless exhaust combinations to listen to. People have videos posted on everything from inside the truck to judge what will keep the Wife off your back to a really good one with a resonator delete and a Flow master.
If I cut the resonator off of my DII I'd pick up a cheap turn down to scuff up and paint flat black so it's Heard and Not Seen. The turn down addresses a few issues;1.The sweep of the exhaust tip points the exhaust towards the ground while the Angle / cut at the end of the exhaust tip actually lowers the exhaust decibels a bit from a | straight cut exhaust tip(don't know the complete "How-Why it works answer" but I'm sure its probably on Wikipedia somewhere.2.The sweeped tip is tucked up a bit more than the resonator or a big honking chrome exhaust tip so it's less likely to get smashed off by trail obstacles.3. The hacked off exhaust pipe isn't blasting the floorpan and the gas tank with hot exhaust and dangerous fumes (see part 1 of 1 again).
wildstylz
01-24-2011 04:04 AM
txbdq
08-07-2009 12:08 PM
