Wiper Blades 2000 Disco II
Old Jul 2, 2010 | 09:47 AM
Buy 2 new D1 wiper arms, apx. $16 a piece, then you can use whatever wipers you want including the new generation wipers that Bosch and others are making in a 21".
Old Jul 13, 2010 | 12:40 PM
jafir's Avatar
Originally Posted by Disco Mike
It is not so much that you can't do a cut to fit blade, but the D2 wiper arms as well as the spring assembly become weak and don't give you the proper tension to the glass.
So is this probably what is causing my rear wiper on my 03 discovery to not touch most of the top on the rear window? Is my only option replacing the wiper arm, because of the washer sprayer being built in? On my 96 it sprays from the rear body pillar, so I'm guessing a disco I arm won't work for the back.
Old Jul 13, 2010 | 09:04 PM
JavaRacer's Avatar
Same issue here. Misses a good amount of the top part of the rear window. I had assumed all this time, that the blade itself was the the cause, but hadn't considered the arm. Anyone else have this problem? Is the solution a new rear wiper arm?
sorbet35
Jan 10, 2014 09:43 AM
TRIARII
Jan 3, 2014 11:18 AM
stonecold
Aug 4, 2009 12:49 PM
phidelt583
Nov 14, 2008 10:29 PM
mrjcrew
Apr 22, 2008 10:47 PM
