Your Modded Land Rover here:
#43
#44
Yes I did come up with a solution as mentioned earlier in this thread. All the edges will be riveted/angled upwards about an inch so to trap in all deposits and liquids, allowing for quick easy cleanup via a standard vacuum cleaner or a damp rag. As for installation of the plates there are 2 options. 1.) Apply the plating then drill 4 strategically placed holes and secure with short screws. B.) the plating is heavy enough to stay put without screws or any other permanent setup. This method is more ideal should you ever wish to remove the plating. Plus your carpets wont be damaged so resell value wont be jeopardized. If anything this plating could preserve the condition and coloring of your carpets because they will not be exposed to typical deposits - the plating will take all the beating.
You and SlangInSanJuan are at oppsite ends of the spectrum. He is repairing/replacing a rusted thru floor while you are wanting to protect factroy carpets.
Allow me to shed some light on your theories. The rust thru ain't primarily from the stuff off the bottoms of your shoes. Look at the thread on the Water Ingress, Discoveries are known to leak at the front windshield, both sunroofs, rear cargo doors, the Alpine Lights (windows) and various other places. Not to mention heater cores that will soak and ruin your front carpets , clogged sunroof drains that will leak and ruin headliners, other leaks that will soak cargo area pads, plus all the little holes from the factory that go thru the metal floorboards and start corrosion in lots of small places from below.
So I would not be convinced that your proposed solution will be a good one.
Only in a well undercoated vehicle with excellent carpets, then you should never allow them to get wet so don't take it out on the trails where fording is a possibility.
As far as removing the running boards, mine removed themselves first trail ride I took.
#46
Those were Terrafirma 6* radius arms and QT steering arms when that picture was taken. It now has a 3 link suspension (worth every penny) and I'm waiting on a custom Rovertym steering setup that uses Heim joints instead of regular tie rod ends it also moves the drag link to the front of the axle (makes it a little more prone to hitting stuff) but itll straighten a lot of weird steering angles out. Its also getting coilover shocks up front once I figure out some mounts. As far as skid plates I have a Safari gard gas tank skid to mount up and some weld on diff covers, everything else is pretty mutch home made.
#47
#49
too each his own my friend, the only other color i was considering was the tri-color desert camo, i believe it's called 3-day. It needed to be tan so it matched the interior, not leafy brown.
Danny, im in pittsburgh this weekend for a wedding. How about this fog?????? Are you going to rausch for the event on 11/12?
#50
Since he got his 3 link in, I got his hand me down Terrafirma arms. Here's the most recent shot of my truck. Pretty much stock like Brians..
