18" wheels
Old Sep 11, 2018 | 03:22 PM
Brn2skifst's Avatar
Default 18" wheels
Has anyone found an 18 X 9 wheel that will fit the Disco V? I'm guessing an ET 40 would fit but will they clear the brakes and suspension? I'd like to put a 275 65/18 on it.
Old Sep 27, 2018 | 04:41 PM
DeckB's Avatar
https://www.comp.co.uk/products/prod...pd1881-299-229
Old Sep 27, 2018 | 06:24 PM
"LR5 fitment available soon." Has there been a update on this?
Old Sep 27, 2018 | 06:27 PM
DeckB's Avatar
Supposedly they became available mid-August.
Old Sep 27, 2018 | 06:30 PM
Cool good info
Old Sep 27, 2018 | 07:22 PM
abran's Avatar
from what I read, not available.
Apparently the issue is the rear brakes!
From the TuffAnt site:
OFFSET - THE GOOD
A good step forward for the New Discovery is that the factory offset is reduced from the previous model. With the standard factory 19", the offset has reduced from ET53 to ET39. This reduction does two things; Firstly, the lower offset means the load is closer to the vertical centre of the wheel, which means the load is more evenly distributed. Secondly for steel wheels, this means clearance can be increased when the wheel is moved more outboard.
NEW REAR BRAKE - THE NOT SO GOOD
​Whilst the front brake caliper is basically the same as the previous model, Land Rover has upgraded the rear caliper to a larger unit, even larger than the front unit. Sadly, this means the Original TuffAnt 18" does not quite fit and a new design has needed to be undertaken. As with the original design, a new engineering design, prototyping and testing process needs to be undertaken, most of which is now completed.
Old Sep 28, 2018 | 09:56 AM
Brn2skifst's Avatar
Thanks for the tech explanation.
Old Sep 28, 2018 | 03:35 PM
Hayseed_D5's Avatar
OFFSET - THE GOOD
You are talking the LR brakes to D5, correct?
Old Sep 28, 2018 | 09:45 PM
abran's Avatar
Yes, brakes on the D5.
Old Sep 28, 2018 | 10:25 PM
BritCars's Avatar
I think that's a comparison of the LR4 to the new Disco 5
The new Disco 5 has the same rear brakes that have been on the full size Range Rover for several years. So if you know of an 18inch wheel that fits the full size Range Rover then it should work here too
