19-a
Old Aug 18, 2019 | 08:39 PM
Groucho123's Avatar
Default 19-a
After 2+ days I got my D-5 back...
While there I tried to do the software update, magically it wouldn't update. Dealer says the server is down...which I think was BS, as it hasn't updated since either.
On top of that the rear doors will not open from the inside no matter how many times the unlock button is pressed. Unless I am missing a setting somewhere? I looked but couldn't find anything that might cause this.
Old Aug 18, 2019 | 09:49 PM
The DareDevil's Avatar
Child safety lock:
https://www.ownerinfo.landrover.com/.../proc/G1807054
Old Aug 19, 2019 | 09:59 AM
Groucho123's Avatar
BTW....according to the Dealer the "upload system" at LR is still down as of now...
Unreal...
Old Aug 19, 2019 | 03:15 PM
andries's Avatar
Not heard of the LR system being down, perhaps it is the dealer's system.
Not the same, but I updated the Nav system this weekend. Guess something at LR works.
Old Aug 19, 2019 | 04:54 PM
Groucho123's Avatar
Yes, I was able to download the map update a couple of weeks ago. Load onto a zip drive then on to the D-5
Old Aug 20, 2019 | 01:11 PM
BelGSX-R's Avatar
Currently downloading Version Number: 08.030.0098.0153. Pretty slow, certainly not due to my internet speed:
Old Aug 20, 2019 | 01:19 PM
vulturez's Avatar
Yeah that is normal regardless of connection speed. This is just a map and POI update, it does nothing to the InControl system. I haven't tried sending it to a virtual USB drive to test if that is the speed limiting factor or if it is on Here's network side.
Old Aug 20, 2019 | 06:36 PM
andries's Avatar
The Nav downloads are probably throttled to prevent network overload on their end, given the multiple GB per map update. This doesn't or shouldn't affect the systems for dealers to download for SW updates for the InControl, IP and other ECUs on the vehicles.
All that said I haven't seen any reports of JLR systems being down for multiple days, which still makes we wonder if it was just a dealer issue that the OP had to deal with.
Old Aug 21, 2019 | 12:01 AM
ToiletDuck's Avatar
So to install 19A we go to the dealer or I can do it all on my own PC now using a USB?
Old Aug 21, 2019 | 07:39 AM
vulturez's Avatar
19A can only be installed by the dealer
Once 19A is installed it is unknown as to what updates can occur over the air. I have heard that there is a 19D in the wild, but I have not seen confirmation. But I can confirm since 19A on my vehicle (2017) no over the air updates have been available.
Map updates are done via the USB drive (Points of Interest & Streets) and have always been done as such.
