2018 TD6 Battery Draw
Old May 23, 2025 | 01:12 PM
clarkemichael86's Avatar
6th Gear
Default 2018 TD6 Battery Draw
I recently bought a used 2018 TD6 Luxury and I love the thing. A few weeks into ownership, I hopped in and the low battery warning flashed on the screen. I thought maybe I left a light on or something, it didnt happen again for a couple more weeks. Then it started happening more frequently, almost every time we got in it, low battery. I was about to take it in when I noticed, one day after we had parked it in the driveway, all the lights for the various transfer case selections, including Lo and the Autostart light were flashing, 20 minutes after we had parked the car. I realized that they would do this until I started it again, killing the battery overnight. My original fix, dont let the autostart kill the engine when you park it, use the ignition button. So we got used to turning the autostart off and it seemed to solve the problem, except, it came back. Now we have to restart and turn off the vehicle, sometimes a couple times, before it stops doing this. Anyone had this problem? Its almost like losing what mode the transfer case is in and just blinks.
Old May 23, 2025 | 02:18 PM
tss118's Avatar
Sounds like it might just be time for a new battery. I would get your current battery tested. These vehicles are temperamental to low battery voltage.
Do some searching, but with 5 minutes of effort you can make the auto stop/start thing go away very easily. It is so invasive on the TD6..
Old May 23, 2025 | 05:37 PM
6th Gear
I'll give it a shot! Its my first Land Rover, I am still learning the ropes.
Old May 24, 2025 | 10:58 AM
Kajtek1's Avatar
You don't have LowJack, or scanner or anything else installed on your Disco?
I have the same problem, occasionally when I plug ScanGauge in it.
Disco software in such occasion will not let the car go to sleep and it will kill the battery.
There suppose to be software update for the issue, but my local dealer butchered the update.
Old Jun 9, 2025 | 06:48 PM
dinkeldorf's Avatar
Similar story - low battery warnings (on a less than 1 year old battery). Then it died requiring CAA / AAA boost service to get home. Bought a Dewalt battery charger with recondition mode, problem has gone away,
Also: Check the battery age. Costco US & Canada have 7 year warranty.
Old Jun 9, 2025 | 07:14 PM
6th Gear
Appreciate all the suggestions. Went and got new tires put on it and while it was in the shop had them test the battery. Shop told me the battery was still good but sitting at around 40% charge. I took it home that night and connected the battery to a charger and all the problems slowly went away. A few days after charging everything worked as it should. Still have a couple little annoyances like the front left parking sensor constantly screaming at low speed but, for the most part, it's gremlin free.
Old Jun 9, 2025 | 10:18 PM
canon_mutant's Avatar
We did have that on our "getting long in the tooth" battery. Changed it. No warning since.
Now, to find some reliable tpms sensors.
Kwesi D
Dec 2, 2024 01:38 AM
sol5656
Nov 7, 2024 03:19 PM
LR4USN
Range Rover L405 (Fourth Gen)
Jun 24, 2022 07:01 PM
Tetters
Jan 9, 2022 10:17 AM
Aj6543
Apr 22, 2021 07:19 AM
