'25 Disco Dynamic - couple noob questions
Old Mar 18, 2026 | 08:02 PM
pdxrado's Avatar
5th Gear
Default '25 Disco Dynamic - couple noob questions
First time LR owner, 25 Disco Dynamic with the 3.0L engine. Can anyone tell me:
-is there a way to have temp control "SYNC" be on by default so i dont have to press it every time?
-has anoyone found a way to make the seat's side bolsters open up more than the max open setting? I'm about 6-2 & 220 lbs but even with all the way open it still feels like its squeezing me a little more than i would like. And yes i've opened them by rotating the dial
-is there a way to give the middle row temperature and fan control where it doesnt also change the fan speed up front?
-is everyone's "P" park button below the shifter slow to pop back up after you press it or is something funky with mine?
-what are the best suggested first mods?
Thank you!! Realliy enjoying the way this car looks and drives.
Old Mar 19, 2026 | 01:01 PM
DISCO26's Avatar
4th Gear
Only had car a couple of weeks so can't help with certain things but air con sync stays on unless I turn it off.
One thing I would ask for info is when I have the cars navigation working I get speed camer alerts pop up, when navigation not in use you can see the speed cameras on map but don't get an alert, any way to have alerts when not using navigation - 2026 Disco
Old Mar 23, 2026 | 10:43 AM
Ultron_'s Avatar
6th Gear
- if you press the sync button in you temp control settings in the screen or between the two temp control **** it should stay there by default. I keep my AC on auto/sync to keep temp in the cabin the consistent. You also need to make sure you have a driver profile created with the vehicle so it can remember your driving preferences if you haven't already.
- unfortunately I don't use the seat bolsters. I leave mine folded up. I'm 6"3 180 and I don't care for it since it's narrow like you mentioned.
- the middle row temp is also located in the infotainment screen with the front temp control. Just press the rear button option and it will let you adjust the temp in the middle/3rd row how you would like. You can even lock the temp settings if you don't want your back seat passengers adjusting it which is pretty cool but you'll see all the cool things when you start playing around with the different features.
-my "park" button isn't slow to pop up.
- suggested first mods:
> windshield/window tint
> I also put smaller rims to have thicker tires for my ride comfort and off- roading benefits because I don't like the 21's from the factory. Not a fan of skinny tires lol.
> seat covers and floor mats.
> I also installed a tuner and switched out the air filters for k&N filters. It saves money since they're reusable and better performance.
I sill have more mods I'm going to do also!
Old Mar 23, 2026 | 10:57 AM
pdxrado's Avatar
5th Gear
Thanks for the reply @Ultron_ . QQ: What do you mean by this?
How does one "not use them" since theyre inside the drivers chair?
Old Mar 23, 2026 | 11:26 AM
Ultron_'s Avatar
6th Gear
my apologies. I was thinking about the arm rest lol. There should be a 4 way direction circle looking button near the seat controls that let you adjust the the bolsters inward and outward.
Old Mar 23, 2026 | 11:49 AM
pdxrado's Avatar
5th Gear
Yup no worries. I have adjusted the bolsters outward to the max but thank you. and FWIW I dont use the arm rests either! no need for them.
Old Mar 23, 2026 | 12:17 PM
DISCO26's Avatar
4th Gear
As anybody got an answer to if it is possible to have the speed camera alert active if the navigation isn't being used.
shepl
Feb 19, 2024 11:07 PM
4Corsa
Aug 19, 2022 04:13 PM
Robbiec
Engine & Internal
Aug 9, 2021 04:37 AM
runNride
Dec 2, 2020 08:16 PM
hhalimi
Mar 7, 2012 10:39 PM
