275/55 Tire Pressure?
I still run 44 front and 50 rear. I know a lot of owners run the lower range and say the ride is better but I don't feel that I need a better ride than I get with 44 and 50.
I don't have enough miles on my Yokohamas yet to see if they are wearing more in the center or edges but I do measure it each rotation and will use that measurement to make an adjustment to tire pressures if needed.
epiclr5 (03-19-2021)
Hoping to resurrect this question.
I'm about to put on some KO2's in 275/55/20 on new rims. I typically run the lower (recommended) pressure, 34/37, for everyday driving, and up it to 44/50 if we go somewhere with a heavy load. This summer I'm towing a trailer up the east coast and wondering if 44/50 is enough on KO2's? Do you guys run the lower (recommended) pressure when your payload is lighter?
Also, did any of you have alignment done when you changed the wheels/tires? I currently run 22 inch (with Pirelli Verde All Season) so I'm reducing the the rims size but I think the diameter/circumference is roughly the same.
