32k miles service
32k miles service
Does anybody know what needs to be done on a TD6 for 32k miles The cost to perform the 2nd year / 52,000km scheduled maintenance is approx. $1,440.00 + tax. It includes a full synthetic engine oil and filter change, engine flush w/ BG oil additive, replacement of fuel filter, replacement of cabin/pollen filter, replacement of both engine air filters, DEF top up, complete mechanical inspection, check/adjust all other fluid levels & tire pressures, lubricate all door hinges/latches. can somebody simplify so I can do it myself
angelboing (04-02-2022)
BG products are reportedly very good. I doubt there's a need for an engine flush, nor any need for an oil additive if you use quality oil of the required spec.
I assume you have performed at least a few oil changes already.
There's no way you should go 15K miles on an oil change no matter what the computer or the manufacturer tells you.
Change it at 7.5 K miles and you should have a happy engine.
There is a BG program that provides engine warranty coverage if you use a certain combination of their products and have them installed by a certified BG dealer.
You'd have to read up on the program on the BG website if you are interested.
