Alignment for 275/55/20 AT tires
Old Aug 19, 2022 | 09:34 AM
hevykevy420's Avatar
Default Alignment for 275/55/20 AT tires
A few months ago I put on some larger 275/55/20 General Grabber ATX tires. I immediately had the dealership complete an alignment. When the wife picked up the car they gave her absolutely nothing as far as a computer print out for before/after alignment specs. The car was pulling slightly prior to the alignment, and that seemed to have been corrected. I assumed all was good.
I've been driving the car for about 9 months, and I am experiencing pretty loud tire noise from the front axle at speeds below 40mph. It has been like this since day 1 with these ATX tires. I understand that AT tires are never going to ride like radials, but the noise seems excessive. I've tried rotating and rebalancing the tires, but that has not significantly improved the noticable road noise between 20-40mph.
I'm noticing more pronounced interior edge tire wear on the front axle. I've since requested the alignment specs from the dealer, but they have been unable to find anything. I assumed that they would set camber/caster/etc. correctly for the tires on the vehicle.
Does anyone have any information on what the alignment specs should be for slightly wider/larger diameter AT tires? Are alignment specs for larger/wider tires the same as the OEM size?
I figured since LR sells the discovery trek version with similar tires, that the dealership would align these ATX tires properly, but the more experience I have at my dealership, the more I realize they aren't exactly the most competent or diligent shop around, and effective communication between the shop, the service advisors, and the customer seems to always be lacking.
Toran
Mar 19, 2016 07:39 AM
Eniam17
Jan 31, 2013 04:59 AM
ShadowMerchantBC
May 24, 2011 12:24 PM
jycsalas
Apr 3, 2009 03:33 PM
rbelz
Feb 28, 2008 04:31 PM
