Anybody able to reset service indicator on MY18 or later
Old 01-01-2021, 10:52 AM
aoysgelt's Avatar
Default Anybody able to reset service indicator on MY18 or later
Has anyone been successful in resetting service indicator on MY18 (or later?). I followed procedure outlined elsewhere on this forum and while it kinda seemed to work - I still get service warning indicator (so it did not work). I am OK with purchasing modestly priced (say below $300) OBD2 scan tool as long as it works...
Thank you
Old 01-01-2021, 11:45 AM
Received 1,541 Likes on 1,264 Posts
Where are you located?
Old 01-01-2021, 12:28 PM
aoysgelt's Avatar
US, California
Old 01-01-2021, 12:34 PM
Wrong end of the country for me to try my launch set up
Old 01-02-2021, 07:03 PM
BritCars's Avatar
What process did you follow? Engine off with ignition on (press start without pushing brake pedal). Open drivers door. Hold down brake and accelerator pedal for 30s (some people say a minute, mine is much quicker than that)
Then ignition off
Didn't that work?
If not, are you sure it's a routine service reminder and not some other sort of error?
Old 01-02-2021, 07:10 PM
aoysgelt's Avatar
Then ignition off
Didn't that work?
Yes that was the process. It appeared to be working (car's behavior was consistent with what was expected) but after I was done (and I tried few times) I still get service remainder (something like "service due") message. My car is body shop but when I get it back I can take pic of warning I am getting.
Old 01-04-2021, 03:37 AM
gmfain's Avatar
Stealer did a software update, and mine worked once. Now its not resetting. I'm in Georgia ArmyRover, what you got?
Old 01-24-2021, 04:42 PM
RyanLR3's Avatar
I have a '17 and followed the above procedure. It says it that it resets, but the mileage doesn't change in the next service menu.
Old 01-24-2021, 06:10 PM
Sent you a PM
Old 02-09-2021, 01:46 AM
christianmotox's Avatar
Same here, tried the manual procedure a few times but the counter keeps saying 0.
I even tried one of those diagnostic tool tablets, and I got an error saying that the procedure failed.
Quick Reply: Anybody able to reset service indicator on MY18 or later
