Anyone have the schematics manual?
If someone has the manual that shows all of the parts and how they go together could you please post? Having issues fueling mine after a plastic cap went down the fuel line. It must be pretty close to the cap as I put in about .25 gal and it backs up clicking off the gas pump.
Could you use a wet/dry shop vac to suck it out if you can make a good seal around the filler?
Maybe try it when the fuel level is low so you don’t suck up too much gasoline?
Maybe even attach some garden hose to the end of the shop across to snake it down there closer to the object?
