Best OBD Scanner Tool?
Old Apr 7, 2024 | 10:07 AM
Elzot's Avatar
Default Best OBD Scanner Tool?
Hi. Can someone recommend a good reasonably priced OBD scanner for my 2020 Discovery?
I'm not looking for dealer-level capability, but one that can provide useful diagnostics, reset codes and turn on/off certain functions (e.g. reverse dip mirror without memory seats). Thanks!
Old Apr 8, 2024 | 11:23 AM
adam5's Avatar
GapIID seems to be most popular for JLR
Old Apr 8, 2024 | 05:45 PM
ponderosajack's Avatar
I have no idea if this scanner will let you code mirrors or seats but it did have a huge list of diagnostic monitoring.
I used it to monitor transmission fluid temperature to check for proper fluid level during my transmission service.
It is much better than my more expensive Foxwell paperweight.
Worth a try for such a low price:
V-gate OBD2 in the port, $20 at Amazon, and Car Scanner App on my phone to connect to the V-gate via Bluetooth
Old Apr 9, 2024 | 10:47 AM
sowrco's Avatar
I have a Launch CRP909E. About $330. Super-useful, it even performs the service resets. It may be a bit much for you. My mechanic son said "the launch pad is the best bang for the buck".
Old Apr 9, 2024 | 11:15 AM
Elzot's Avatar
Thanks. That's actually the one I was leaning toward. $330 seems reasonable.
Old Apr 9, 2024 | 12:02 PM
462disco's Avatar
GapIID tool is the best. You can activate and reset certain parameters that generic OBD2 readers can't touch. Gen 4 was recently released, and supports the 2020+ DoIP interface.
Pricey, but highly recommended.
https://www.gap-diagnostic.com/products/iidtool/
Old Apr 10, 2024 | 05:08 AM
gmfain's Avatar
I too have the launch CRP 909. Does pretty good. You can use it on multiple vehicles.
Old Apr 10, 2024 | 09:58 AM
sowrco's Avatar
This is a very good feature!
Old Nov 7, 2024 | 08:35 AM
mtaylo32's Avatar
@gmfain @sowrco I just picked up the Launch CRP909E and am able to connect to my wife's 2010 Volvo V70, but am having issues connecting to my 2017 D5 TD6 HSE. Have either of you had that issue? If so, any solutions? It is giving me "Before the diagnosis starts, please confirm that the device has been connected to the obd interface.". Thanks in advance!
Old Nov 7, 2024 | 08:42 AM
gmfain's Avatar
@mtaylo32
Yes this has happened to me.
Do a hard reset on the scanner. Then let it update again. should work after that.
