Center Console "Secret Compartment"
Thanks - although I wouldn’t use the word “jammed.” It’s not physically stuck. Instead, it appears to be triggered electronically. I’m going to take it to the dealer, but I do wonder if there is supposed to be an electronic lock feature for the compartment.
I don't think there's anything electronic about that panel opening. I push the button and it releases it, no matter what the screen is on.
The door just jams. The next time its stuck, just press the release button while pulling on the volume **** to open it.
It's an easy dealer fix, I hear. I'm not making a trip to the dealer for it until my next oil change.
It's not electronic. It just has a dampened hinge that opens the door slowly. You still have to push it closed.
+1
This is the correct answer.
My "secret compartment" also jams intermittently (won't open when press the "open" button)--especially when it is cold outside. When it does jam, the trick is to pull gently on the volume **** while simultaneously pressing the "open" button. It sounds like this is a known issue with a fix. I'll just wait until my annual service for the fix.
2020 Discovery HSE Luxury Si6 Fuji White (Current)
2015 RRS Autobiography Fuji White (Former)
2011 RRS Supercharged Fuji White (Former)
2008 LR2 Fuji White (Former)
