Considering a 2018 TD6 HSE 35k miles
Hi all,
just sold our 2015 LR4 and looking for a used Discovery. I found a contender in a 2018 Discovery HSE TD6 with 35k miles. We have had 4 Land Rovers so far so kind of know about the quirks and issues. Been trying to research as much as I can on the diesel.
It recently came back from an inspection at an independent shop and while most of the notes were fine there is one section I’m hoping to get some insight on…
PUL ENGINE CODES, LIGHT WAS ON BUT ISNOW OFF VEHICLE HAD NUMEROUS HISTORY AND INTERMITTENT CODES, WE HAVE CLEARED AL CODES, TEST DROVE AND 1 CODE HAS RE-SET, THIS IS FOR THE IPMB, IMAGE PROCESSING MODULE B. THIS MAY REQUIRE ADAS
CALIBRATION AND SOFTWARETO PROPERLY CLEAR THIS CODE. NO LIGHT IS ON DASH.
im not familiar with the IPMB or image processing part. It does list minor front end damage, which I’m ok with as it was sold as a CPO shortly after. The carfax also indicates regular service at a LR dealership.
also worth noting that this vehicle is not local so haven’t seen it in person.
any thoughts or insights?
thanks
thanks
35k miles is pretty low for a 2018.
The number of codes is possibly concerning - but could also be from low battery voltage which can kick up codes that don't mean anything
I'd be more worried about the returning code - module error, electronic issue - can be very hard to diagnose and to repair
Would get full service history, understand the story incl the codes and the front collision. If I were you I'd ask them to resolve the codes before buying.
But - it's not a rare car. And this one has accident damage and potentially some module of electrical issues. I would prob pass.
The the forward camera probably needs calibration or might be faulty. If it's clean I would scoop it up if it's a good price only if you're not going to drive for short trips regularly. Land Rover publishes information to that extent. The diesels survive if driven on highway and towing. If you're going to stop and go with minimal mileage daily hold out for a gasoline powered Discovery.
would $29k-$31k be considered a good price? I tend to think yes but open to thoughts. We actually don’t drive a ton as I work from home and wife can walk to work. So it will be in the garage a decent amount of time. But when we do drive it will be a combination of longer highway trips and around town driving. Not sure if the sitting in the garage part is an issues as long as we get the longer highway trips in
No personal experience with crankshaft failure. It does happen, I'm not certain anyone know exactly what excites that failure mode. I'm willing to accept the risk. Mine is at 100k miles now, with what I assume if the original engine. You'll read about higher mileage failures I'm sure. Meh
TD6disco
02-07-2024 04:25 PM
