Cracked sunroof
Old Apr 14, 2019 | 04:54 PM
edwingow's Avatar
4th Gear
Default Cracked sunroof
My wife got in her 2018 Discovery HSE this morning and noticed that there is a large crack in the sunroof. There does not appear to be any sort of impact mark that would have caused this - has anyone experienced an issue similar to this?
Old Apr 15, 2019 | 09:24 AM
andries's Avatar
Ouch, do you have a picture of the crack?
Don’t have one nor recall reading about a crack in the moonroof.
Old Apr 15, 2019 | 11:47 AM
edwingow's Avatar
4th Gear
Default Picture of the crack in the sunroof
It was difficult to get a shot where the crack really stood out without being under cover. Unfortunately there’s a crack in the stucco of the porte corchere above the image that makes it difficult to differentiate the actual crack in the glass. I’ve drawn a line around the actual crack.
Old Apr 22, 2019 | 01:48 PM
jaguardoc504's Avatar
Could have been a multitude of things.
It is pretty easy to swap out though.
Remove the trim pieces on both sides and remove the screw mounting the glass.
Re-install and adjust
Old Oct 7, 2019 | 06:48 PM
Disco5tv's Avatar
8th Gear
Default Same thing here...
I have the same problem with my 2017 Disco. I opened the shade and looked up a few days ago and there is a crack going all the way across. Also no "star" pattern from impact or anything. I've had a lot of sun/moon roofs over the years, never had one break before. Did they fix your's under warranty?
Old Oct 8, 2019 | 12:49 PM
edwingow's Avatar
4th Gear
They did not. I ended up having the sunroof replaced under our insurance as it fell by our windshield replacement coverage. I'm terribly unhappy with Land Rover over all this, especially since I explained that we had been experiencing a wind noise coming from the sunroof from the day that it was new and were told that it was normal. Interestingly, once the sunroof was replaced, the wind noise went away. Of course the sunroof replacement was done by a 3rd party, so Land Rover won't consider the possibility that it was a fitment issue from the factory.
Old Mar 2, 2020 | 12:29 PM
longtrip68's Avatar
Default I have a cracked sunroof too
I looked up the other day and found a crack in my sunroof that goes all the way across the sunroom. And when I look down on it from up top, it actually is worse as it runs along the edges all the way from rear to front. It doesn’t look like there is any external damage at all. I just so happen to have a 32k service tomorrow morning, so I will bring it up. Of course I would like it covered under warranty, but I am not holding my breath.
Old Mar 2, 2020 | 02:54 PM
edwingow's Avatar
4th Gear
I wish you good luck on this - my dealer's service department seemed more interested in covering their own asses than actually taking a close look at the issue. Definitely a disappointing experience.
Old Apr 23, 2021 | 05:32 AM
Blupontiac's Avatar
4th Gear
Default Me too! Whilst stationary!!!
Myself and my wife returned home the other day and parked the car with our son asleep in the back seat on our drive. We were discussing what to do with him when the front sunroof whilst the cover was closed went crack! No over hanging tress or anything to fall on it no impact whatsoever. Opened the cover and watched the crack which appeared on the drivers side halfway way along grow toward the centre of the glass like a scene from Jurassic park! We’ve never actually opened the sunroof and the temp was around 12 degrees with no fluctuation? So now we’ve got to sort that out🤦🏻‍♂️
Old Jul 19, 2021 | 07:09 AM
discosport's Avatar
Default cracked sun roof
i opened my sunroof yesterday and noticed a crack across - all the way from one side to the other. There had been no impact or anything that would have caused the crack. I wonder is anyone has an idea of how much it would cost to get it fixed
