Crankshaft Pulley
Old Jan 31, 2024 | 09:15 AM
mtaylo32's Avatar
Default Crankshaft Pulley
Hey all, I have a '17 HSE TD6 with 112,250 miles. I'm doing the idler pulleys, water pump, timing belt, serp. belt and tensioner this Saturday as a part of routine maintenance, but wondering if I am in need of a crankshaft pulley? If this is a failing part does this mean I am setup for the crankshaft failure some folks have reported, or is the crankshaft pulley only really responsible for powering accessories? It visually looks like there is some play in the crankshaft pulley, but could also be an optical illusion, I'll capture a video later today. Is that part considered routine maintenance? From what I've read it seems like it is supposed to last the "life" of the engine... There are only sounds when the truck is idling, the sound does not get louder when accelerating. Thanks in advance!
Old Jan 31, 2024 | 02:58 PM
sowrco's Avatar
I think the pulley is basically inert/passive. I can't see why it would need to be replaced unless it is damaged. I'm assuming it is removed to allow the cam belt cover to come off?
Old Jan 31, 2024 | 09:32 PM
RyanLR3's Avatar
I replaced mine because it looked like it was wobbling, the new one looked exactly the same. Don't waste your money replacing it.
https://landroverforums.com/forum/ne...wobble-106632/
Old Feb 1, 2024 | 04:52 AM
gmfain's Avatar
Take some pics!
Which timing belt tools did you buy?
Old Feb 1, 2024 | 08:59 AM
mtaylo32's Avatar
@RyanLR3 Thanks! That is good to know. I've been a little paranoid the last couple of days thinking this might be a larger issue, but glad to hear it doesn't appear to be anything. I'll keep you posted once I dig in on Saturday.
Old Feb 1, 2024 | 09:02 AM
mtaylo32's Avatar
Originally Posted by gmfain
Take some pics!
I definitely will do my best @gmfain ! You are the master of detailed tutorials, hoping to get on your level.
I will be tackling this job with the help of a mechanic friend who already had a set. I will let you know what set he has.
Old Feb 1, 2024 | 09:06 AM
gmfain's Avatar
Thank you for the compliment!
Looking forward to your post!!
Old Feb 1, 2024 | 10:40 AM
sowrco's Avatar
Well at least there's a ton of room in front and you don't have a fan to remove. I watched one video where the mechanic marked the crankshaft end and did not lock the flywheel. That would make the job even easier but it sounds a bit sketchy.
Tony Luna
May 10, 2023 11:40 AM
Nate_1996Disco1V84.0
Apr 21, 2021 12:35 PM
QuakerJ
Mar 24, 2014 02:46 PM
jbkroh
Oct 19, 2012 09:40 AM
