Def
angelboing (11-30-2020)
The following 2 users liked this post by sobiloff:
angelboing (12-01-2020),
ar077 (12-07-2020)
My experience:
I have ran this from begining: https://www.walmart.com/ip/BLUEDEF-D...RoCnhIQAvD_BwE
Buy one of these: https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Cut the bottom off, add a short flexible tube directed back down inside .
Park D5 on an incline, front end uphill.
Using the modified bottle, you can fill tank in 10 minutes.
Hope this helps.
Hope this helps.
The main thing to look for with DEF is if it has the appropriate ISO spec (ISO 22241) and then you want to try and buy the freshest DEF possible. Learn how to read DEF date codes and make sure your DEF wasn't sitting outside in any heat.
I bought a DEF funnel similar to this one below and it worked great.
https://www.ebay.com/itm/Schwaben-DE...IAAOSwLPle~Dy~
Diesel Exhaust Fluid - DEF.
The following 4 users liked this post by AirRyan:
