Did I screw up the front brake?
I recently attempted to change the front brake pads and rotor discs on my 2019 Discovery Td6. Everything went smoothly until I over-tightened the upper 13mm bolt on the caliper bracket, and unfortunately, the bolt's head broke off. I managed to extract the remaining bolt. However, when tightening the new bolt, I couldn't achieve the required 26 ft-lbs of torque. The bolt just keeps turning. I lowered the torque wrench setting and it seems the torque is about 15 ft-lbs now. It's not loose, at least for now. I put everything back together and took it for a test drive. It seems fine. Did I screw up? Should I order a new caliper bracket (part number LR110405) for peace of mind? Is there any other way to fix the problem without ordering a new bracket?
I did hold the inner when I just started torquing the bolt, but stopped holding it when it no longer turned with the bolt. So, could this still be the issue, or do you think I might have damaged the thread of the 'nut'? Is it dangerous to drive now?
