Caliper Bolt Torque Setting?
Old Mar 24, 2016 | 11:24 PM
za105's Avatar
Default Caliper Bolt Torque Setting?
RAVE says the front caliper bolts are to be torqued to 129 pounds. I was torquing it down to that setting and the head snapped off. I had a real nice afternoon and evening trying to extract the screw before realizing I could get a replacement guide pin at AutoZone for a few bucks. Wasted day aside, is that really how tight I'm supposed to torque the caliper bolt down to?? That seems excessive.
Old Mar 25, 2016 | 06:11 AM
coors's Avatar
Caliper Guide Pins typically range from 25-35 ft/lbs
Caliper "Carrier" Bracket Bolts typically range from 35 - 125 ft/lbs
I believe you may have referenced the wrong bolt spec in Rave? But kudos to you for trying to identify the proper torque spec.
Old Mar 25, 2016 | 09:28 AM
Alex_M's Avatar
Calipers are really one of those things you just crank down with a ratchet and say "eh, good enough". You can torque to spec if you want, but not necessary.
Old Mar 25, 2016 | 09:42 AM
za105's Avatar
Oh gosh. Yup, I see where I went wrong. A couple lines down is "brake caliper guide pin bolt" at 22 lbs. Versus actual caliper bolt at 129 lbs. Phewie. Thanks for the tips guys.
cappedup's Avatar
Remember 129ft/lb is literally like standing on your ratchet wrench if you weigh 129lb and it's 1ft long.
So you can kinda idiot check the value by saying "would I stand on my ratchet, given my weight, and the bolt is 8mm."
I think the caliper bolt is 8mm or 3/8".
Old Mar 25, 2016 | 05:37 PM
OffroadFrance's Avatar
129lbs/ft is way excessive for either guide pin bolts or caliper carrier bolts.
I rarely use a porque wrench for most things apart from engine internals, head bolts and alloy wheel lug nuts.
I'm with cappedup on this one, think 129lbs weighing down on a 12 inch long wrench. These original bolts also have threadloc on them.
focusontheworld
Oct 21, 2012 01:00 AM
Rover Chris
Oct 3, 2009 04:22 PM
arives350
Aug 13, 2009 05:02 AM
SmyLeOrElse
Apr 9, 2007 10:00 AM
