Discovery V 3rd Row Seats Issue
Old Jan 13, 2026 | 10:09 AM
BenRumary's Avatar
4th Gear
Default Discovery V 3rd Row Seats Issue
Hi all.
I have a 21 plate discovery D300 HSE R Dynamic.
My third row electric seats which don't often get used have started not staying up. They come up and rock three times seemingly trying to lock in and then go back down.
No blockages have been found and no error codes or warning lights...
Any clues very welcome.
As I say they don't get used very often so very frustrating when they are needed they don't work.
Thanks.
B
Old Jan 13, 2026 | 01:28 PM
bones519's Avatar
Had the same issue with a 2022 P360. the seat wouldn't lock and after the car tried a couple times would go back down. Started within first year of ownership. Had it repaired at the dealer under warranty after a couple of visits. Turned out to be an issue with the sensor and seat frame that wasn't aligning properly. Dealer tried to calibrate a couple of times which made it better but not totally fixed. Ended up replacing the seat frame (again under warranty). Seemed to have fixed the issue but wouldn't be surprised if it happens again. Have heard / seen others with this same problem.
Old Jan 14, 2026 | 02:06 AM
BenRumary's Avatar
4th Gear
Sounds expensive to fix out of warranty. 😔
Old Jan 14, 2026 | 11:09 AM
bones519's Avatar
Ha, yeah didn't ask what it would cost out of warranty. Though not sure if a full replacement was needed. Could have just been easier to submit warranty for replacement than try to fix it. Can't imagine these things are that complicated.
Old Jan 30, 2026 | 10:11 AM
BenRumary's Avatar
4th Gear
Had the third row seats recalibrated which worked while in the workshop. By later in the day tried to use the seats and they were back to not working....the mind boggles!
Old Feb 4, 2026 | 08:49 PM
timc166293's Avatar
Had same issue, my solution was replacing the modules under the front driver's seat. There was a water leak on the windshield, went down the a pilar into the footwell, where the modules are. Good luck
Old Feb 9, 2026 | 08:09 AM
Ultron_'s Avatar
6th Gear
I have the same problem with my 2022 p360 also. I had it fix under warranty but the problem came back again but I'm out of warranty now and I not trying to pay out of pocket for it. Quick tip: if you want the seats to stay up or down, just force/hold the seat with your hand in the position you want the seat to stay in after you request the seat to go up or down from the vehicle. The sensor/motor in the seat will sense the pressure thinking something or someone is in or on the seat and it will stay put. For example: When I request the seat to let up, I will just hold it in place when it tries to go back down basically making the motor in the seat think a person is in it so it can stay up or vice versa when you want it to stay down. It's more convenient to use the buttons in the rear of the vehicle instead of the infotainment since you need to be physically there to hold the seat in place.
Old Feb 9, 2026 | 08:17 AM
BenRumary's Avatar
4th Gear
I did think of that but it's quite a force.you need to force them to stay up and I didn't want to break them anymore than already broken.
Old May 14, 2026 | 09:34 AM
d2jlr's Avatar
Angry 3rd Row Seat Saga
Purchased Discovery Metropolitan 2023 which has same issue with 3rd row seats...been at Parks Aberdeen for 4 days in April and returned to me with same issue.
Now back in again...so far 2 days and still waiting for update.
Joined group so can keep abreast of ongoing issues with Discovery.
Liked Ultrons comments to hold seat in place but had been worried like Ben that may damage seat mechanism so never tried it !
avartanian
Nov 25, 2023 12:00 PM
1979rover
Jan 24, 2021 11:16 AM
djbackpain
Jan 19, 2021 09:30 AM
Jslice
Mar 19, 2019 05:28 PM
