downsize from 21" to 20" wheel cause suspension issues?
Old Jun 7, 2021 | 02:23 PM
nwr1967's Avatar
Default downsize from 21" to 20" wheel cause suspension issues?
I've read a lot of posts on doing basic wheel size changes on the forums and it seems like it can be done without problems. I have a 2019 Lux with 21" and would like to go down to 20" for a better off road set up (actually 19" would be ideal but it seems not a good selection of AT tires in 19" out there). In my research I called the dealer to see what they'd say about finding 20" wheels and they said I could only go UP in wheel size on my Disco, and not down, because "it would mess up the suspension".
This sounds like dealer BS, but of course I need to find out if there is any truth to this. Does anyone know? And how about voiding the warranty? Thank you!
Old Jun 7, 2021 | 07:05 PM
BritCars's Avatar
No issue with the suspension. That sounds made up...
You can downsize the wheel and use a tyre with a bit more sidewall to give you the same total rolling diameter. So it won't impact Speedo, cause ride height or clearance issues. etc
However the only consideration is whether you have 20inch wheels of the right specs (hole pattern, center bore, offset etc) - could use other LR ones. And whether the smaller wheel will clear the brakes.
20 should be fine and I think you can go to 19 for some wheel types but you would want to check brake caliper clearance
Old Jun 7, 2021 | 07:27 PM
LR disco 5's Avatar
As BritCars said 20's should be fine its just some dealer BS my buddy downsized from a 21 to 20 and his disco is running fine mine is sitting on 20 as standard so I have no clue so you should be fine
Old Jun 7, 2021 | 11:27 PM
DiscoNight5's Avatar
Considering that you can order a Discovery with 20" wheels, sounds like the dealer is trying to upsell you.
kurtisblo
May 17, 2021 09:16 PM
Snafu / Disco Fries
Mar 13, 2015 02:56 PM
binvanna
LR4
Feb 26, 2013 05:38 PM
SiloMan
Aug 11, 2012 03:32 PM
davidlt
Mar 2, 2008 04:20 PM
