Drive Assist Side Camera Reset?
Old Mar 28, 2019 | 10:49 AM
Disco V's Avatar
Default Drive Assist Side Camera Reset?
When using Drive Assist, my drivers side camera is aiming at approx. 10 o'clock, when the proper position is more like 11 o'clock or even 11:30.
I should be able to see the front wheel but I am aimed well left of it.
Is there a way to reset this?
Old Aug 17, 2020 | 03:56 AM
gmfain's Avatar
I'm having same issue.
Any luck resolving?
Old Aug 20, 2020 | 04:17 AM
gmfain's Avatar
Ok, It has to be re calibrated with LR's software/diagnostic ........
Hope this helps.
Old Sep 11, 2020 | 08:20 AM
Disco V's Avatar
Hope this helps.
Yep...required dealer service. The invoice stated "Found inside of camera loose. Removed drivers door panel and mirror and replaced the camera in drivers mirror. Updated IPMB and tested."
Covered under warranty.
Has worked perfectly since.
Old Sep 14, 2020 | 04:14 AM
gmfain's Avatar
Update on my issue is the same. Camera is loose inside sealed unit. I will have to use my extended warranty to repair.
Not sure how it happened?
disco5fl
Oct 19, 2023 09:00 PM
Neels Hamman
Range Rover Evoque
Sep 4, 2019 07:34 PM
SoCalWiley
Jun 18, 2018 12:59 PM
jaym69
Range Rover Evoque
Jun 16, 2018 07:25 AM
Rearden Steel
Jul 30, 2012 07:16 AM
