Extended Warranty Providers
Old May 5, 2024 | 05:16 PM
kartikhegde's Avatar
4th Gear
Default Extended Warranty Providers
Hello all!
I just purchased a CPO 2020 LR Discovery HSE TD6. I am loving my trips to the mountains (I live in WA).
When going through the purchase, the finance team offered an extended warranty beyond my CPO (which expires in one year). I usually decline them, but in the case of my first Land Rover, I would like to hedge my maximum repair costs. They said that Land Rover doesn't offer extended warranties and that they partner with Allstate to provide one. Knowing them to be a good company, I decided to negotiate and purchase it with the option of searching for other providers later (you can cancel and get a pro-rated refund).
It cost me $5100 + taxes to add 5 years, 100k miles, and a $100 deductible. I am now in the market to see if there are better options. Unless it's significantly different, I would stay with this, as they are my local dealer.
For people in the US, who are the other providers? Will it be cheaper?
Old May 5, 2024 | 10:31 PM
adam5's Avatar
Kartik, welcome aboard.
The price seems about average; I would recommend verifying if the coverage starts at the in-service date, OR the date of contract purchase.
Allstate, Zurich, Fidelity are the common ones I came across, but there are plenty of others.
For reference, I bought Fidelity 7yr/100K for $5700 out the door.
Do us a favor, post your coverage info on this thread, to help others
https://landroverforums.com/forum/ne...rranty-105985/
Old May 5, 2024 | 10:32 PM
adam5's Avatar
Also,
Old May 5, 2024 | 11:39 PM
4th Gear
Originally Posted by adam5
Also,
Haha, thanks Adam! I will post on that thread.
Some pics below (already took her off-road)
Old May 5, 2024 | 11:47 PM
adam5's Avatar
nice job; digging the storm trooper color
Old May 10, 2024 | 08:13 AM
tykurez's Avatar
5th Gear
Thanks for posting this. I too bought a CPO 2020 HSE about 6 months ago and I will definitely purchase an extended warranty before the CPO period is up. Let me know what you end up going with
Old May 10, 2024 | 10:19 AM
adam5's Avatar
keep in mind, extended warranty pricing is done in yr/mileage tiers (15k -25k, 25k-35k and so on). you may want to compare what it would cost by the time the CPO period is up vs purchasing the contract earlier. some underwriters may be picky about factory warranty being active as well.
all the best
Old May 11, 2024 | 10:49 AM
asmith's Avatar
Do these extended warranties all cover the diesel-emissions junk that California has hobbled our TD6s with? The only significant maintenance items I've ever had on my 2018 TD6 at 63k miles have been with diesel emissions equipment and it's always been hard to convince LRNA to cover much of that under the emissions warranty. I won't be keeping the TD6 for much longer unless I can figure out some sort of insurance against future costs in this area.
Old May 11, 2024 | 10:17 PM
adam5's Avatar
Emissions aren't covered by Fidelity as far as I know.
File Type: pdf
Old May 13, 2024 | 12:02 PM
adam5's Avatar
For future reference, here's the info from the owner's manual:
EMISSION CONTROL SYSTEM WARRANTY COVERAGE [G2426883]
The following is a list of the parts that are covered under the Federal Emission Control System Warranties.
Air Induction System
Air cleaner assembly
Intake manifold
Turbocharger assembly
Turbocharger intercooler
Supercharger assembly
Supercharger bypass actuator
Supercharger intercooler
Supercharger intercooler pump
Supercharger intercooler radiator
Exhaust System (including diesel Selective Catalyst Reduction (SCR) system)
Catalytic converter¹, ²
EGR cooler and valve housing assembly
Exhaust manifold
Exhaust pipe (manifold to catalytic converter)
SCR catalyst¹
SCR heater control unit
SCR injector
SCR oxidation catalyst¹
SCR particulate filter⁵
SCR pump
SCR tank
SCR tank filler hose
SCR tank interior module
Ignition System
Glow plug
Glow plug control module
Ignition coil
Spark plug
Positive Crankcase Ventilation (PCV) System
Breather hose
Breather valve
Oil filler cap
Oil separator
PCV valve
Powertrain Control System
Engine/Powertrain control module¹, ³
Engine/Powertrain control module sensors and switches
Malfunction Indicator Lamp (MIL)¹, ⁴
Transmission Control Module (TCM)¹, ³, ⁸
Variable valve timing solenoid
Variable valve timing unit
Mild Hybrid Electric Vehicle (MHEV) System
MHEV high voltage battery
MHEV Battery Energy Control Module (BECM)¹,³,⁷
Battery Integrated Starter Generator (BISG) ¹,³
Evaporative Control System
Fuel filler cap
Fuel tank
Fuel tank filler pipe/hose assembly
Fuel tank leak detection assembly
Fuel vapor purge valve
Fuel vapor storage canister
Fuel Delivery System
Fuel injector
Fuel injector supply manifold
Fuel pump control module
High pressure fuel pump assembly
In-tank fuel pump assembly
Throttle body assembly
Braking Control System
Anti-lock Braking System (ABS) control module³, ⁶
Miscellaneous Items
Thermostat
Adaptors, belts, boots, brackets, bushings, clamps, clips, connectors, couplings, covers, ducting, fasteners, filters, flanges, gaskets, grommets, hoses, insulators, labels, pipes, seals, shields, sleeves, spacers, straps, tubing and wiring used with the systems listed above.
¹ Parts covered for eight (8) years or 80, 000 miles (130, 000 kilometres), whichever occurs first.
² Includes the downpipe where integral to the catalytic converter assembly.
³ Includes hardware, software, and/or calibration.
⁴ Includes the instrument panel where the MIL is not a separately serviceable part.
⁵ Covered for eight (8) years or 80,000 miles (130,000 kilometres), whichever occurs first, where the SCR particulate filter is integral to the SCR catalyst and/or the SCR oxidation catalyst.
⁶ Covered for (8) years or 80,000 miles (130,000 kilometres), whichever occurs first. Includes hydraulic control unit (HCU) where anti-lock brake system (ABS) control module is not a separately serviceable part.
⁷ Includes MHEV high voltage battery where MHEV Battery Energy Control Module (BECM) is not a separately serviceable part.
⁸ Includes the transmission control valve assembly where the TCM is not a separately serviceable part.
