Front led spotlights - grill integration
Old Aug 13, 2020 | 01:25 PM
discoiceland's Avatar
Default Front led spotlights - grill integration
Anyone tried this solution for front led spotlights - looks rather good this way. Or any other good suggestions?
https://www.lazerlamps.com/disco-5-g...ation-kit.html
Old Aug 13, 2020 | 01:28 PM
1979rover's Avatar
Looks nice, but $$$.
Lucky8 makes a nice bracket which you can then add the lights of your choice onto.
Old Aug 13, 2020 | 01:47 PM
yes indeed expensive but it is with the lamps. You mean this bracket here? Do you reccommend lights on these?
https://lucky8llc.com/collections/di...5-light-mounts
Old Aug 13, 2020 | 02:13 PM
1979rover's Avatar
Several folks on here have those brackets and those same Baja Designs lights (they're even more expensive than the one's you posted). The Baja's are very highly rated, btw.
Old Aug 13, 2020 | 06:27 PM
Hayseed_D5's Avatar
The Lucky 8 brackets look too aftermarket for me unless you go full out on all the kit. The lazerlamps look more integrated - like they are on purpose. I think best is the A Bar with lights.
For lights, also look at the KC HIlites SLimlite LED's. Put them on one my Wrangler's A Pillar and very bright and compact. BD's are a phenomenal light but the KC's great too and are a fraction of the cost of the BD's.
Old Aug 30, 2020 | 04:25 PM
Got the integration kit and the LED spotlights. Used the opportunity and ordered a black grille. Started cutting it, but probably better to put the grille first on the car.
This will upgrade the front a lot.
Old Sep 3, 2020 | 11:42 AM
almost there
Old Sep 4, 2020 | 04:53 AM
DarkyUK's Avatar
There is a seller on eBay doing these with a custom wiring loom so you don't need to cut any wires, might be worth asking if they will do the wiring loom separate for you?
Old Sep 4, 2020 | 11:31 AM
Thanks - next step is wiring but will have that done by a specialist so will show him this. But got the grille on - and I like the look.
Maybe next to change the letters to black, or just remove them ... or keep it as is ...
Old Sep 4, 2020 | 11:37 AM
DarkyUK's Avatar
Looks really smart, I changed the letters to black, looks loads better.
eBay item 223948501241 if you wanted their contact details.
