How do I setup OTA updates?
Old Mar 12, 2020 | 02:45 PM
ToiletDuck's Avatar
Default How do I setup OTA updates?
I had mine in the dealership getting the window fixed and an update done a couple months ago. I think you needed a certain update to be able to do them in the future over your Wi-Fi. Does anyone have a pdf or guide on how to setup the Disco to use house Wi-Fi to do updates? I just installed a mesh Wi-Fi system so I have access out in my garage and want to let it do it’s thing.
on a complete other note... where is the second battery for this vehicle and how often does it need to be replaced? She’s starting to sometimes crank too long and I think I might need a new battery.
Old Mar 12, 2020 | 07:05 PM
BritCars's Avatar
There is only one battery. Behind the right hand side panel in the boot / trunk area
What's the voltage level when engine is off?
Old Mar 12, 2020 | 11:32 PM
andries's Avatar
Set it up to connect to your wifi network under settings and connectivity
https://www.ownerinfo.landrover.com/.../proc/G2134435
Once on the wifi you can go to settings and I believe updates. The latest I was able to install was 19C, had to be on 19A or 18D for SOTA to work.
Old Mar 13, 2020 | 06:47 AM
Drake Anderson's Avatar
...or if you have active 4G service you pay for, it will update over cellular.
longtrip68
Feb 5, 2019 10:26 AM
houm_wa
Nov 21, 2017 10:50 AM
Chris Schafer
Jun 6, 2016 12:32 AM
legendbridges
Jul 10, 2012 07:04 PM
nijones25
Aug 13, 2010 01:22 PM
