InControl Updates Failing
Old Jun 1, 2020 | 08:14 AM
  #21
AirRyan's Avatar
Originally Posted by Hayseed_D5
20A was successfully installed last week. Have had it with no issues.
Today, I am getting a data useage overage message - says to put more data on my plan.
This problem is:
1) I have the unlimited plan
2) Plan was auto-renewed on May 28th
3) Logged in and current useage is well less than 1 GB
Anyone experience this? Does this have anything to do with the system update?
Yes. It appears system wide as many on a D5 FB page have reported the same. May or may not be tied to 20A, but it does appear to be a system wide outage of some sort.
Old Jun 1, 2020 | 08:45 AM
  #22
user 3948377440's Avatar
This problem is:
After I upgraded to 20A I have received the same messaging. I have looked into my cellular data settings and it seems that there is a default setting with a data limit of 100MB per month creating the above mentioned message. You can change the settings based on your plan and the message goes away. I guess this is a new feature in 20A.
Old Jun 1, 2020 | 09:07 AM
  #23
AirRyan's Avatar
Originally Posted by LR#3
After I upgraded to 20A I have received the same messaging. I have looked into my cellular data settings and it seems that there is a default setting with a data limit of 100MB per month creating the above-mentioned message. You can change the settings based on your plan and the message goes away. I guess this is a new feature in 20A.
I saw that, too. I reset my allowance and set it to like 1TB, even though I have an unlimited plan with my own data provider. Even after turning off the vehicle and getting back in, the message still came up, like every 20 seconds mind you. Hopefully JLR will get this fixed ASAP.
Old Jun 1, 2020 | 10:00 AM
  #24
Hayseed_D5's Avatar
Yes, I tried upping the limit and it did not fix the issue.
Old Jun 1, 2020 | 11:21 AM
  #25
Hayseed_D5's Avatar
I drove again this morning and used my cell phone as a hotspot and turned off the data in the car. Still get the message and weather and live do not work. Traffic in satnav works and it does show using data.
Old Jun 3, 2020 | 12:21 PM
  #26
Stroh's Avatar
I had this message and haven't yet been updated to 20A. I also have unlimited data and set the data limit setting in connectivity settings to off. I toggled it back to on and set a high limit and still received the message. I was still getting traffic data for the maps but the weather would not work. It seems to have resolved itself as I did not see the message today.
Old Jun 3, 2020 | 01:12 PM
  #27
Hayseed_D5's Avatar
Mine fixed itself yesterday.
Old Sep 4, 2020 | 02:50 PM
  #28
longtrip68's Avatar
Originally Posted by BritCars
I've had dealer do them at annual service and always worked fine for them. System has improved a lot in 18 months
TeamEdition - how are you using Bluetooth and CarPlay? I thought it only works on a cable? I use it a lot (by cable) and it works perfectly. My only gripe is there isn't more control over the screen layout and choices - but that's an Apple issue. I use waze and Spotify all the time.
Britcars
the Apple CarPlay screen layout and app choices is done through the Settings menu of your iPhone. On your iPhone, go to Settings>General>CarPlay>Land Rover Discovery>Customize
There you can Add, Delete, and rearrange the order of the apps displayed on your Rovers screen. If you do this while CarPlay is currently displayed in your car, you can watch it affect as you reorder stuff
Old Aug 13, 2021 | 01:47 PM
  #29
mgazall's Avatar
4th Gear
2018 Disco5 HSE LUX Just bought from dealer with 32k mi. Went to set up the InControl app but no ability to connect to the internet hot spot or normal wifi. Dealer could not connect either to do an software update. Said it is a a problem with the I. M. C system, which is your info screen and actual modules assembly. Said the wifi is not becoming available because the actual wifi does not know to turn itself off and thus cannot get it to download manually - Said they are going to have to escalate the case now with J L R north America, Any one have experience with not being able to connect WIFI and any successful outcomes ? Thanks very much if you take time to post.
TennMan
Nov 30, 2021 05:00 PM
gilakinlr4
LR4
May 2, 2020 07:18 PM
rjchankalian
Aug 15, 2019 03:30 PM
tgras1
May 16, 2018 01:51 PM
