Keyless Entry Not Working
2018 HSE Si6
I recently developed an issue where the unlock function of the keyless entry system is not working.
When I approach the vehicle with the key in my pocket, I am unable to get the doors to unlock.
Even if I hold the key next to the door handle, it will not unlock.
The vehicle only unlocks when I press the unlock button on the key fob.
The vehicle starts fine and when I exit the vehicle, the doors lock as they should when I touch the door handle.
I just can’t get the unlock function to work.
Any thoughts?
Any thoughts?
Happened to me this weekend.
I could unlock with the buttons but not by the door handle. Later it worked, then later still it did not.
To start the car I had to hold it under the steering column (where the car sends wireless power like a smartphone charger mat) to give the fob enough juice to deactivate the immobilizer.
The battery in the remote is too weak.
I replaced the battery (CR2032) and it now works again.
I only realized as my wife’s fob wouldn’t even lock/unlock with the buttons whereas mine would so I realized the problem was the fobs not the car.
Replaced both batteries following a YouTube video.
I replaced the CR2032 battery in both remotes with no improvement.
Remote works as designed just fine for starting the car and locking the car (by touching the door handle), but the unlock function stopped working for some reason.
I'm a big fan of LR and of this Disco but the gremlins can be downright maddening at times.
