Leaking Transmission on MY2017
Old 06-09-2018, 07:01 PM
instantfob's Avatar
Default Leaking Transmission on MY2017
Found this TSB on NHTSA site regarding the issue I am having with my new Discovery.
Issue started 20 days new and 600 miles.
As of today it has been in the dealership for last 30 days.
My dealership has swapped out 2x transmission oil pans and a new transfer case.
Yesterday I was informed that it now needs a new transmission which is currently on national backorder status.
If your DV is having similar issue, please check if your VIN matches to the range below.
January 3, 2018 MANUFACTURER COMMUNICATION NUMBER: SSM73709 ATTACHM
Components: POWER TRAIN, EQUIPMENTNHTSA ID Number: 10130711
Manufacturer Communication Number: SSM73709 Attachm
Summary
Issue: Oil leaking between the automatic transmission and transfer case assemblies which in some instances is being misdiagnosed potentially leading to repeat repairs, for example leaks incorrectly being identified as coming from the rear transmission oil seal or oil pan. Oil weeps through the aluminium casing in the rear extension housing of the transmission in the base of the pocket around where the steel D clutch steel tube is embedded. Affected Vin Range
(LG) Range Rover: 347117 - 378677
(LW) Range Rover Sport: 148715 - 179554
(LW) Range Rover Sport: 683503 - 695139
(LR) Discovery: 013353 - 046041
gclasse (06-11-2018)
Old 06-09-2018, 11:24 PM
gclasse's Avatar
mine is within those numbers, and recently found a drop of oil in the garage floor!
Old 06-09-2018, 11:36 PM
instantfob's Avatar
Stick a large piece of cardboard under the truck after a nice drive. Any HVAC condensation will evaporate clean and only oil left behind.
The collection spot is the lowest point of the exhaust pipes which is in line with the door mirrors. Bring that to the dealer for reference too.
Insist they do a road test after they attempt any repairs because transmission needs to build up pressure to push fluid out of the pores of the metal casing.
Good luck. I hope your dealership will provide better loaner vehicles. I have been driving a Discovery Sport SE for a month now. (Hornburg Santa Monica)
Old 06-15-2018, 03:16 PM
gclasse's Avatar
Instafob, mine went to the dealer today!! Will let you know what will be the resolution! Did you get a loaner immediately??
Old 06-15-2018, 03:26 PM
instantfob's Avatar
Hornburg Santa Monica has Enterprise Car Rental handle their loaner program. I have been driving their loaner Discovery Sport SE for 30 odd days now. According to my SA, my transmission is due to arrive on June 19th. Their typical choices of loaner cars are Jaguar XE / XF / RR Evoque / Discovery Sport SE
Buy a Disco and drive a Disco Sport SE .... The Land Rover experience haha
Old 06-19-2018, 07:11 AM
gclasse's Avatar
D5 at the Service department since last friday and the only update i have received so far is that the SUV is soon to be checked and they will contact me with next steps!!
Old 06-23-2018, 09:10 AM
gclasse's Avatar
Got this from the Topix Land Rover Website, mine was confirmed with the symptom and is now awaiting for a New Transmission.
Old 06-23-2018, 10:16 AM
instantfob's Avatar
I am glad your dealer went straight to the transmission swap route. Mine went thru multiple parts before getting to the transmission swap approved. Picking mine up on Monday. 45 days later.....
Old 06-23-2018, 11:02 AM
gclasse's Avatar
Have to say that your event helped a lot to quickly address the issue...hope to get mine soon!!
Old 06-27-2018, 09:04 AM
instantfob's Avatar
Got my car back yesterday with the new transmission and no leaks!
Quick Reply: Leaking Transmission on MY2017
