Is LR Discovery good for towing a boat?
Old Mar 24, 2022 | 10:33 AM
RichardinFL's Avatar
Question Is LR Discovery good for towing a boat?
Hello All,
I'm new to LRs, wondering if 2019 Land Rover Discovery HSE (V6) is a good and safe car to tow a boat?
I'm interested in towing a 23ft/4500-5500Ib boat, I live about 10 - 15 miles from the beach.
Has anyone done this? please share your experience (pictures)!
Thanks
Old Mar 24, 2022 | 07:12 PM
LR disco 5's Avatar
This si an amazing towing vehicle I suggest asking @N559br for more info he tows a huge boat and many people on this forum tow travel trailers much heavier than boats you should be absolutely fine and I tow a light pop-up a lot and it loves it.
Old Mar 24, 2022 | 07:50 PM
stillruns's Avatar
An Avalon with a trailer hitch could probably tow 5,500lbs. You'll be fine.
Old Mar 25, 2022 | 06:43 AM
bkjecu94's Avatar
I tow this all over NC... Mountains to the beach. Zero issues moving and stopping. I did add an electronic trailer brake using the pre-wire that came with my Disco. Many boat trailers have brakes (hydraulic surge) and most states require depending on the trailer weight.
Old Mar 25, 2022 | 07:59 AM
Thank you for your reply.
Will I need an "electronic trailer brake" if I tow a 5000lb boat?
Old Mar 25, 2022 | 08:21 AM
bkjecu94's Avatar
I would highly advise a trailer brake of some kind with that weight... You do not want your boat to beat you to the stop sign on a hard stop! That said, a boat that size may have a trailer with the hydraulic/surge type brake built into the trailer. Best to speak to the seller and look up the laws of your area, state laws differ in the USA. In NC I believe the weight is 4,000 lbs for a brake requirement.
Old Mar 25, 2022 | 11:27 AM
Thank you @bkjecu94
Old Mar 26, 2022 | 11:13 AM
LR disco 5's Avatar
make sure you get the right plug in connection also when buying the controller
Old Mar 26, 2022 | 06:44 PM
bkjecu94's Avatar
Correct... my trailer brake uses theTekonsha 3065 harness. This type of harness is readily available for ~US$15. It is made primarily for Ford trucks.
Old Mar 26, 2022 | 06:52 PM
LR disco 5's Avatar
the controller I bought was the hopkins forgot the model number though
