Maintanance
Old 06-02-2021, 11:38 AM
LR disco 5's Avatar
Default Maintanance
I was just wondering how often do I have to change the oil on TD6 engine because I've heard 8k but I don't know in km or miles??? also what other maintenance should be done and how often????
Old 06-02-2021, 03:19 PM
Sasquatch86's Avatar
8k miles for oil and filter. 16k miles for fuel filter. I think the air filter, diff oils, transfer case oil and trans filter are 60k miles but I'm not definite. Wish maintenance was published in the owners manual.
Old 06-02-2021, 04:54 PM
LR disco 5's Avatar
Do oyu know what oil do you use for the diesel engines? TD6
Old 06-04-2021, 12:32 PM
Jhartz's Avatar
Maybe open the owners' manual . . .
Old 06-07-2021, 04:09 AM
gmfain's Avatar
It's the Ford engine, So I use the Ford oil from Rock Auto.
MOTORCRAFT SAE 5W-30 F-150 Diesel Motor Oil https://www.rockauto.com/en/parts/mo...0QFA,oil,12138
6.5 quarts, 8,000 miles oil, 20,000 fuel intervals
other items I use from Rockauto
prices may vary
Rockauto
air MANN C35126 $20.79
CABIN AIR WIX 24511 $10.72
fuel MAHLE/CLEVITE KL1044 $36.79
OIL WIX WL7490 $13.55
MANN HU826X $5.02
WIPER LEFT TRICO 2417B $6.74
WIPER RIGHT TRICO 2017B $7.77
WIPER REAR TRICO 12I $4.01
VALEO 604486 Wiper Blade $ 6.36
VALEO 604483 Wiper Blade $ 6.37
angelboing (06-08-2021)
Old 06-07-2021, 05:17 PM
LR Max's Avatar
This is fantastic. Thank you.
Also glad you gave wiper information. I am a fan of new wipers often so good to see viable wiper replacements.
gmfain (05-10-2022)
Old 06-07-2021, 07:58 PM
BritCars's Avatar
You should check it meets the required Land Rover spec
With Diesel Particulate Filter (DPF): SAE 5W-30 meeting Jaguar Land Rover specification STJLR.03.5005.
Without DPF: SAE 5W-30 meeting Jaguar Land Rover specification STJLR.03.5003.
Mechano2020 (07-31-2021)
Old 06-08-2021, 03:34 AM
gmfain's Avatar
The Ford spec is called out in the manual too. Of course it meets the LR spec and the Ford spec., its a Ford engine.
From Tech spec:
Specification SAE 5W-30 engine oil meeting Jaguar Land Rover specification STJLR.03.5005 or WSS-M2C934-B. If unavailable, 5W-30 engine oil to ACEA C2 specification may be used
File Type: pdf
Old 06-08-2021, 03:37 AM
gmfain's Avatar
I use the Valeo wipers. Exact fit.
Valeo is a French global automotive supplier. Good products, mainly European market.
Old 06-08-2021, 12:50 PM
LR Max's Avatar
On this note, does anyone have the differential (locking and open diff) and transfer case oil specs? Specifically for a 2019? I do have the rear differential locker. Wondering if the special fluids are the same from the LR3/LR4 days.
I had bad bearings on the rear diff of my LR3 and that sure as crap isn't happening to my D5. I'm keen to change fluid early.
Quick Reply: Maintanance
