Modify electric seat tilt travel range
Any way to modify the front seat tilt to go lower than the current limit? The lowest position is still too high for me. The front edge of the seat creates a pressure point and cuts off my circulation. It's odd...the rear of the seat (height adjustment) goes very low, but the front does not. It's same on the passenger side, so it does not seem to be a malfunction. I thought there might be a setting somewhere...under the seat, a screw or limiter, mounting position...that could change the tilt range to a lower limit. Thank you.
Thanks. Yes I can do that and it does help some but not completely. Also it's not the seat position I'm looking for.
