Modify electric seat tilt travel range
Old May 4, 2021 | 10:44 AM
nwr1967's Avatar
Default Modify electric seat tilt travel range
Any way to modify the front seat tilt to go lower than the current limit? The lowest position is still too high for me. The front edge of the seat creates a pressure point and cuts off my circulation. It's odd...the rear of the seat (height adjustment) goes very low, but the front does not. It's same on the passenger side, so it does not seem to be a malfunction. I thought there might be a setting somewhere...under the seat, a screw or limiter, mounting position...that could change the tilt range to a lower limit. Thank you.
Old May 4, 2021 | 07:32 PM
BritCars's Avatar
I don't think you can drop the front any further. But can't you lift up the rear of the seat base to change the angle a bit? That should stop your pressure point
Old May 5, 2021 | 09:58 AM
nwr1967's Avatar
Thanks. Yes I can do that and it does help some but not completely. Also it's not the seat position I'm looking for.
DiscoBuckeye
Jun 12, 2016 08:29 AM
rovernoob
Feb 4, 2015 08:33 PM
deepessions
Oct 7, 2009 12:56 PM
LitleSuzie
Jan 18, 2008 01:58 PM
rover2003
Nov 7, 2007 09:53 AM
