Need help. Center storage (behind climate controls) won’t open
So here is an interesting one for you folks. Got in places my key in the center storage (Behring the climate controls). Got home, the storage compartment won’t open. Is there some weird trick to getting open? I have the key in there so basically anyone can drive the car if I can’t get it out. Anyone had a simmilar issue? Know of a way of getting it open manually?
Any help appreciated. Thanks.
No, one push is all. And it applies to 2017. Mine worked ok for a couple times then stopped opening without pulling on the top of it. First dealer said they shimmed it and fixed it but it still didn't work. Another dealer fixed it correctly and it works with one push. I guess I should check it again to see if it's still working.
Gonzalo Cabrera (07-25-2020)
I have this issue as well, car is just 5 days old and I use one had to push the button and use left temp control to pull. It works! Next service appt will need to address it.
