Normal Height Only
Old Aug 24, 2023 | 11:03 PM
Jondl18's Avatar
Default Normal Height Only
Disco 5. 18 plate. 50000 miles.
I am getting the “normal height only” warning come up after about 5 minutes of driving and my suspension switch turns off.
when I start the car the suspension works perfectly well and the car ride height is fine.
has anyone else had this.
my car is now out of warranty and LR want £225 just to diagnose the fault.
Old Aug 25, 2023 | 03:38 PM
abran's Avatar
Sounds like your compressor is going out. Need to read codes to confirm.
Old Aug 25, 2023 | 06:00 PM
Chucktastic's Avatar
Something similar happened to ours under warranty. The dealer replaced the air tank since it had a crack.
Old Oct 16, 2023 | 05:12 PM
geekinc's Avatar
You need to pull codes. The code I was getting was filling too slowly, or something to that effect. On mine, there was a crack in the plastic connector that connects the pump to the airline. It sits on the side of the pump cover and is a part that you can get from the dealer. You will also need to replace the push fit connectors as they are a consumable. I can get into a lot more detail if this is something you want to tackle, but the price of a new pump assembly is $800-$1200 and I wanted to see what I could do before I spent the money.
Juancl
Jul 11, 2023 11:24 AM
Chum
Oct 6, 2021 06:35 AM
Steven Schorer
May 1, 2021 06:38 PM
Manicoti
Jan 23, 2011 09:22 AM
bhorwhat
Sep 9, 2009 06:41 AM
