P049B-00 EGR "B" Flow Insufficient Detected
Old Jun 3, 2023 | 09:32 PM
gmfain's Avatar
Default P049B-00 EGR "B" Flow Insufficient Detected
Got a cel today.
2017 TD6
Anyone had this code?
thanks
Old Jun 8, 2023 | 02:02 PM
gmfain's Avatar
My mechanic says more than likely will need to replace the EGR Valve.
I will use my extended warranty.
He said Its a 4 hour job. I could take it off and clean it. Its a big job.
So I will let him do it this time, under warranty.
Have to let them diagnose it Monday .
I will update ya'll.
Old Jun 9, 2023 | 11:09 AM
mtaylo32's Avatar
Glad to hear it's covered. Did he give you a ballpark on what that cost would be without a warranty?
Old Jun 9, 2023 | 01:46 PM
gmfain's Avatar
He only said the EGR Valve is around $1200, plus labor.
I will know more Monday.
Old Jun 10, 2023 | 11:45 AM
ar077's Avatar
Got a cel today.
2017 TD6
yone had this code?
thanks
Just out of curiosity, what is the impact of insufficient EGR flow in the Td6? Exhaust gas recirculation is the bane of diesel truck owners because it carbons up the air intake system, including the EGR valve, which is PITA to clean or replace. Many diesel truck owners install a blocking plate between the exhaust bypass tube and the EGR valve to prevent this from happening. Alternatively, the ECM can be programmed to not only prevent the EGR valve from opening but to also disable the resulting cel (I plead the fifth).
Since you have an extended warranty there's no reason to not get it fixed but, for future reference, you might do some research to see if there are any downsides to ignoring a recurrence of that cel, other than emissions non-compliance.
Old Jun 11, 2023 | 07:34 AM
gmfain's Avatar
So far little impact. I have still been driving some.
I will look into a delete in the future.
Old Jun 12, 2023 | 01:15 PM
gmfain's Avatar
The Continental Warranty I bought doesn't cover the EGR valve.
I requested a copy of my warranty. I misplaced my copy.
I got the less expensive policy, $3,995.00.
So my bill is $1,713.00.
I will take the EGR valve they removed, and clean it, put in on a shelf for the next time.
Old Jun 12, 2023 | 05:18 PM
ar077's Avatar
Any chance you could post some photos of the EGR valve, before and after cleaning it (and would soaking it in a gallon of parts dip be a suitable way to clean it)? Also, what is the Land Rover part number of it?
Old Jun 13, 2023 | 04:40 AM
gmfain's Avatar
Yes sir.
I will post it.
Old Jun 17, 2023 | 08:47 PM
gmfain's Avatar
I picked my D5 up today.
Here is the pics of the EGR.
When I have time to clean it, I will post those pics too.
Part # LR069681
