Payload capacity
Old Feb 19, 2022 | 11:50 AM
LR disco 5's Avatar
Default Payload capacity
Is it just me or is the payload capacity super high on the disco because if I'm doing the math properly
it'd be
6,724 - 4900 = 2,089lbs which is super high in my opinion am I calculating wrong
Old Feb 19, 2022 | 01:11 PM
The Insider's Avatar
it'd be
Well, 6,724-4900 is 1,824....However, your math aside the payload capacity is dependent on the powertrain. The official US specs for the D5 3.0 are as follows:
D5 3.0 Petrol
Curb 5,160 lbs
Gross 7,075 lbs
This translates to a load carrying ability of 1915 lbs. That may sounds like a lot but remember this is a seven passenger SUV. The average American male is about 190 lbs but let's round to 200 pounds for clothing, personal items and easier math. That's 1400 pounds right there. Then assume a situation where you put 150 pounds in the boot/trunk and 150 pounds on the roof. Now you're up to 1700 pounds.
The capacity reflects the potential situations the vehicle might face.
Hope this helps.
Old Feb 19, 2022 | 01:52 PM
LR disco 5's Avatar
Thanks man I did the math and I ended up with a payload of 800 left after the tongue weight of the trailer and plus the passengers in the vehicle
Old Feb 19, 2022 | 06:07 PM
dinkeldorf's Avatar
The D5 payload is really quite good. As a long timer RVer if you're at all worried, go to a scale when not busy and measure it all out. The problem with most RVs is the cargo hold & propane tanks put their weight almost directly onto TV tongue rather than the usual 12.5% to 15% transfer rate. Our process was nothing but passengers in the TV, everything else in the middle of the RV, empty freshwater & holding tanks.
Old Feb 21, 2022 | 06:15 PM
ponderosajack's Avatar
My 2017 HSE Si6 is nowhere near the spec'd empty weight of 4700 or 4900 lbs.
I forget what I measured as, but I did post it here previously.
It was well over 5000.
Old Feb 21, 2022 | 06:44 PM
LR disco 5's Avatar
well the owners manual says for the Si6 4700lbs dry and the TD6 4900
Old Feb 21, 2022 | 06:52 PM
That's what it says but not what mine weighed when I checked it.
Old Feb 21, 2022 | 07:28 PM
LR disco 5's Avatar
did you have anything in the car because that sounds kind of odd
Old Feb 22, 2022 | 04:42 PM
A little bit but not multiple hundreds of pounds.
omarica7
Mar 11, 2014 08:12 AM
Tracecroft91
Mar 5, 2013 05:37 PM
Chris-bob
Oct 4, 2010 03:59 PM
LR4LIFE
Nov 6, 2007 10:23 PM
northgadisco
Apr 28, 2007 06:24 PM
