Preventative Maintenance
Old Mar 13, 2023 | 03:32 PM
mtaylo32's Avatar
Default Preventative Maintenance
Hey all, Just picked up a 2017 HSE TD6 over the weekend with 96,000 miles. I had a pre-purchase inspection completed and the truck is in terrific shape! 3/4 life remaining on the brake pads, 3/4 life on the tires, oil change recently completed as well as DEF service. Just drove it 11 hours home, this thing is tight and seems to match up to the maintenance records. Very clean for mileage.
Is there anything I should be doing now or at the 100,000 mark to stay up-to-date on the maintenance? Planning to cut the oil change intervals in half. When does the transmission need to be serviced? How frequently should I be swapping the differential fluid? This one does have the center and rear locking differentials. Are there any diesel additives I should be using that will help with longevity?
To be fair, I'm not familiar at all with the diesel platform, but super excited to learn more about it. I love working on our vehicles and plan to do as much maintenance as I can, but also have access to a good independent shop.
Thanks in advance!
Old Mar 13, 2023 | 08:02 PM
David42six's Avatar
Timing belt and fuel pump belt at 112k but I would do it at 100k.
This is for a 2017 Discovery, L462.
Old Mar 14, 2023 | 10:46 AM
mtaylo32's Avatar
Thanks for uploading this! Will definitely download for my own records. Appreciate the help on the timing belt as well.
Old Apr 21, 2023 | 10:38 AM
mtaylo32's Avatar
Anyone have part numbers to do the Camshaft timing belt, tensioner, and idler pulley service, along with the fuel pump drive belt and tensioner service for a 2017 Diesel HSE? Thanks in advance!
Old May 4, 2023 | 12:19 PM
Karel's Avatar
Timing belt and fuel injection pump almost due.
Old Sep 28, 2023 | 02:01 PM
RyanLR3's Avatar
I didn't see a response to this. I'm also interested. I'm also interested in both procedures if someone has them as well. Much appreciated!
Old Sep 28, 2023 | 02:07 PM
mtaylo32's Avatar
See if these help @RyanLR3 . I haven't done the procedures yet, but pulled the documents from topix.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Sep 29, 2023 | 08:34 AM
RyanLR3's Avatar
Thank you
Old Jan 4, 2024 | 01:25 PM
mtaylo32's Avatar
@RyanLR3 Have you done the camshaft timing belt, tensioner, idler pulley, and fuel pump drive belt and tensioner swap yet? If so do these part numbers look accurate?
Timing Belt: LR078913
Idler Pulley: 1311306
Timing Belt Kit Fuel Pump: LR016656 (Looks like for other models, not L462)
Many thanks!
Old Jan 4, 2024 | 01:33 PM
RyanLR3's Avatar
Many thanks!
I haven't yet. I will keep everyone posted.
