Pushing the Tongue weight
Old Feb 13, 2022 | 03:02 PM
LR disco 5's Avatar
Default Pushing the Tongue weight
Hi Still deciding on buying a trailer came around this 5500 lb dry and 6900lb GVWR jayco and the only issue is the tongue weight its 730lbs would this be safe to tow or just drop it?
Old Feb 15, 2022 | 05:52 PM
n559br's Avatar
I'm running about 600 tongue weight and the airbags hold it with no problem. What happens if you put 5 of your friends in back of the car. That should give you an ideal of squat with the trailer on.
Old Feb 16, 2022 | 03:19 PM
The Insider's Avatar
The air suspension will manage it and adjust accordingly, but you absolutely need to make sure you're running the correct tyres at the recommended "normal" pressure. Do not tow use the low pressure/comfort option.
Make sure the trailer brakes are performing correctly and properly inspected.
Old Mar 8, 2022 | 11:28 AM
jaacina's Avatar
The rear axle load capacity is 4100 lbs. Check it out via a CAT Scale. I have towed over 30k miles with mine towing a Solaire 240BHS with a Hensley Cub.
Fenix
LR4
17
Oct 15, 2021 09:00 PM
LR disco 5
Aug 7, 2021 11:02 PM
Ehloo
May 14, 2021 10:09 AM
carid
Member Group And Special Buys
Jul 22, 2016 05:56 AM
GeoC
Jul 17, 2008 07:19 PM
