Pushing the Tongue weight
Hi Still deciding on buying a trailer came around this 5500 lb dry and 6900lb GVWR jayco and the only issue is the tongue weight its 730lbs would this be safe to tow or just drop it?
I'm running about 600 tongue weight and the airbags hold it with no problem. What happens if you put 5 of your friends in back of the car. That should give you an ideal of squat with the trailer on.
Make sure the trailer brakes are performing correctly and properly inspected.
carid
Member Group And Special Buys
Jul 22, 2016 05:56 AM
