Replacement shocks for 2018 D5 TD6
Old Jan 2, 2023 | 07:09 PM
dsturnerville's Avatar
4th Gear
Default Replacement shocks for 2018 D5 TD6
I had both front shocks on my 2018 D5 TD6 fail and need to be replaced (100k miles on the odometer). That airbags on the shocks work fine and did not fail, however the internal monotubes failed. Obviously I have to replace the whole combined unit.
Anyone know of a good source for aftermarket or low mileage salvage?
I can't afford to pay for new OEM units and there doesn't seem to be any good aftermarket options for the D5 that I can find.
I decided to go ahead and replace the rear shocks (not the separate air bags) while I'm at it, so I'm looking for those as well.
It's crazy how little there is out there for the D5 even after 5 years of production.
Any tips on how to find some replacements would be greatly appreciated.
Old Jan 3, 2023 | 05:01 AM
gmfain's Avatar
Try Arnott, I have had good luck with there products.
https://www.arnottindustries.com/all-struts-shocks/
Old Jan 3, 2023 | 05:06 PM
4th Gear
They were one of the first outfits I contacted. The do not make anything for the D5 so they referred me to their sister company, Strutmasters, who also does not make anything for the D5.
Old Jan 4, 2023 | 10:04 AM
BritCars's Avatar
Check if they are the same on the Range Rover sport. Might give you some more options if they are.
Old Jan 4, 2023 | 06:43 PM
RyanLR3's Avatar
Can you give some detail of symptoms the vehicle was exhibiting to lead you to think there was a problem and how the failure was ultimately diagnosed?
Old Jan 18, 2023 | 04:57 AM
gmfain's Avatar
https://www.landleaping.com/
try here
Old Jan 20, 2023 | 03:10 PM
LR Max's Avatar
If you do go with Land Leaping, they have a promo code right now. SAVE10. for 10% off.
Just bought some other random crap from Land Leaping. Seems legit.
Old Jan 27, 2023 | 11:50 AM
4th Gear
Extreme body roll, diving into corners. Extreme nose dive when braking and unsettled when hitting bumps, dips.
Finally found a wrecked donor D5 with 13k and took all four shocks.
Installing next week.
Brandon318
Jul 21, 2020 06:40 PM
fc3286
Jul 16, 2013 04:38 PM
gavone1976
Feb 13, 2012 07:05 AM
dadams634
Mar 15, 2011 01:21 PM
EstorilM
Feb 24, 2011 01:52 AM
