Roof Racks
Old 03-23-2018, 03:19 PM
Hayseed_D5's Avatar
Has anyone tried the Voyager rack on the D5?
Old 03-28-2018, 08:22 PM
Bhaney59's Avatar
Looks great!
Old 04-18-2018, 10:14 AM
MikeinNY's Avatar
Default Frontrunner pics
Here ya go.
runNride (10-24-2020)
Old 10-23-2020, 08:54 PM
willche's Avatar
DeckB, do you recall what torx size you used to remove the oem roof bolts? So far, I’ve stripped two torx head because the bolts are so tight.
Originally Posted by DeckB
I installed a FrontRunner 'Slimline 2' about a month ago. Overall I'm very happy with, and can't wait to put it through its paces come camping season. Well built and well thought out.
Install was fairly easy and I was able to do it myself. There are a lot of bolts, so be sure to use a drill/driver with torque control. The caps on the OEM roof rails were a pain to remove.
The mounts sit on 'sleeves' that hold it ~1/2" over the roof rails. It looks like these could be ground down to drop the overall height, but I'd check the sunroof clearance first. May not be worth the effort to gain ~1/4"
There is some wind noise, which I expected and is within what I'd consider 'normal' for a rack. There are two wind deflectors under the front of the rack and I found pushing them ~1" apart seems to help mitigate some of the noise.
Zonk872
02-15-2007 10:28 AM
dinandan
07-04-2006 10:43 AM
stealthn
06-15-2006 02:55 AM
dailyuser
07-29-2005 05:02 PM
Quick Reply: Roof Racks
