Step by Step How to Reset the Service Interval
#31
you might need your firmware updated mine didn’t reset with the procedure they had to update the formware of the cluster to get it to work.
#34
A few months back Stealer did software update to fix oil reset(under warranty).......fast forward.......did and oil change, reset worked.....(reset to 8000)..... came up premature to change at 6000, me scared of oil dilution broke motor parts, etc.... I changed it again.
Low and behold, absolutely will not let me reset it........... out of warranty now...........going to call the stealer today and see if they are going to re-do the fix for free....... Stay tuned.......any thoughts or similar experience?
#35
Ok, I went to the stealer. They told me I wasn't going to be able to reset it, since its the diesel. I have to bring it back to them, 100 miles one way. But its free. That makes it good right? No. I requested a call back from the stealer owner.
I also called JLR Customer Service. Lady said yes you can reset it here is the procedure for the diesel.
https://www.landrovertampa.net/servi...20been%20reset.
I'm going to give it a try today. 1/11/2021
- Turn off your engine.
- Turn the ignition to “on” without igniting your engine (if you have push-button start, press your button once without touching the brake pedal.
- Open the driver’s door.
- Depress and hold the gas and brake pedals for 60 seconds.
- Then turn the ignition to “off” and verify that the light has been reset.
#36
Sorry for the delayed update. The above did not work. My dealer said I have to bring it to them everytime, until JLR has a fix for the diesel versions.
So in the mean time, the CS rep called several people, and confirmed I would have to get it reset at a dealership.
( I am going to try a scan tool in the next few weeks when I meet up with a Rover buddy)
saga continues
saga continues
#38
I might buy the Gap tool later when it fully supports theTD6. I refuse to buy it now just to reset my oil changes.
thanks so much for doing this favor I ask!
