Hi, did anyone replaced tail lights on Dicovery 5 HSE luxury ? How to remove driver side inside trunk rear panel to get to the screws for tail ligjt ? Thank you for help
Hi Jerry P - were you able to solve your problem? I have the same issue now and they tell me replacing the light won's solve the problem. Thank you.
Hi, I am trying to remove the driver side taillight. I removed the loadspace trim per manual, but it seems I need to remove the upper panel (see the picture) as well to remove the vent duct, otherwise I can't get to the taillight screw. Can anyone point me how to? or anyone has manual for that as well? Thanks
Were you able to solve this issue and if yes, then how? I have replaced the original tail lights with EU-spec units, installed by a local Land Rover specialist. However, there is still a problem with the turn signals. The yellow indicators work correctly, but the red lights (presumably the brake lights) also flash simultaneously when the turn signal is activated.
