TD6 5th gear issue. Anyone else?
Old May 2, 2023 | 05:35 PM
Sire's Avatar
Default TD6 5th gear issue. Anyone else?
Hi all,
Well, I did the unthinkable and purchased a 2017 TD6 with 97k miles on it. It was a creampuff, with only one previous owner, and had regular maintenance. The previous owners were an elderly couple who mainly drove it cross country.
I am in the first week of ownership and have now noticed a pattern. When the car is cold and accelerating, upshifting as it gains speed, once it gets to the 5th gear, I experience hesitation and a pulsating and jerking from the drivetrain.
I reached out to ZF USA, and they advised me to do a drain and fill to check on the condition of the transmission fluid. I also contacted the dealer and was able to get some goodwill from them. They told me to drop it off tomorrow for them to check it out. I will keep you posted, but I wanted to see if anyone else here has experienced anything similar.
Thank you in advance.
Old May 2, 2023 | 06:09 PM
BritCars's Avatar
No harm in changing out the fluid anyway. In general these ZF transmissions are v reliable. Have you used a code reader to pull codes from the car? And any warning lights or messages, restricted performance warnings etc?
Old May 2, 2023 | 06:12 PM
Sire's Avatar
Hi, thanks for the reply. I do not have any stored or present codes. No check engine light.
I agree the ZF transmissions are stout. Joe at ZF of USA suggested I check the fluid and speculated that maybe 5th gear solenoid is experiencing mechanical failure.
First though he said to change and inspect the fluid.
Cheers
Ian Savage
Feb 2, 2022 10:09 PM
Snacs
May 11, 2021 08:49 PM
kb24
Mar 8, 2016 08:31 PM
yeager6
Sep 21, 2010 05:45 AM
rumpig70
Nov 15, 2007 03:22 AM
